classic33
Leg End Member
She saw it for herself, real-time.Mrs M was at GLA to take them home..
I use small 'jeweller' type needle nose pliers to prise them off..
this one had two simple points needing 'support' although I have done the previous one without them..
I'll try another method tomorrow, always worth a go and learn from it.
It was supposed to be Sonic...
to save weight and material, everything inside is like a honeycomb-like infill, normally the model is two lines thick, but I had made this 3 thick like the photo here so the outer layer was sturdier, oh well, tomorrow awaits, it took 3 hours 6 mins to print, it is not exactly quick
two supports, The left one has a branch going up to under the snout, these ones just snap off..
Oh well, lazy day tomorrow...
How small are yer jewellers needle nose?
Only two supports to get rid off. From that clump of plastic in the first picture. Looks like there'd be more than that in it.
Sorta solid then, even if it's not all like the outer shell.
Easy tell what/who it's supposed to be in the second picture. Not so easy tell from the first picture.
Is yer latest sticking its tounge out or is that a piece to remove.
Did you see the piece where Gordon Ramsey has had 470 of those lucky cats taken from one of his restaurants, in a week. Not that lucky for him it seems. £7+ apiece, and customers are helping themselves to them.
