Tea? (Part 2)
Status
Not open for further replies.
Speicher
Vice Admiral
As long as the frog is somewhere sheltered and damp then it should be ok. It must have been local enough to have got into the garage and so it should find its way back to where it came from, in due course, now that it is back outside.
Kermit is about five feet from the garage door, so not very far "off course" from his intended route. Thank you Lullabelle, Arch and NT for your advice.
Speicher
Vice Admiral
Sweet :thumbsup:
Wol, are you watching Endeavour on ITV1?
Yes
I do not expect him to go swimming in the sea, and lose his shorts.
potsy
Rambler
My Armchair
TT ? ......................... is that Tubby Touring
:reading:
Night Train
Maker of Things
I have just been in the workshop adjusting the position of my Brompton trailer axle. It was too far forward and so loads tended to be tail heavy. I have moved it back 170 mm and brazed it in position. I'll have to test run it at some point to make sure I haven't overdone it.:unsure:
I also had a panic that I had lost my gas soldering iron kit. I have been hunting for it all evening but eventually found it on my surface planer hidden by a bit of wood!:thumbsup:
I wanted it to repair the motor on my old 57xx pannier tank loco. However, it is still refusing to run.:sad:
:cuppa: now.
It is so warm this evening!:heat: Maybe iced cream would have been a good idea, if I had some.
Arch
Married to Night Train
Salford, UK
I've got a snotty nose.
And just got a text from a colleague saying he thinks our other colleague will be off sick again tomorrow, so we'll be two people doing the job of three. It's normally a lighter day, luckily, but it's going to be hard work.
Better get to bed, I suppose.
Night Train
Maker of Things
:hugs:
I hope you get better soon, and that tomorrow isn't too hard.
Status
