Tea? (Part 2)
Status
Not open for further replies.
Speicher
Vice Admiral
Talking above Languages, next Saturday on BBC4 a German Detective series starting will be. :whistle:
TVC
Wol, I'm not sure about your neighbour.
Speicher
Vice Admiral
I now have a clean patio and a blocked drain. :eek:
The patio slopes away from the house. All along the edge of the patio and under about two inches of pebbles is a flexible hose.
As I understand it, this hose has perforations to allow water from the patio to run into the hose, and then it travels towards a drain. The end of the hose goes under a low wall and meets a much larger drain coming from further up the hill/garden.
I can access the joint of the two drains, by removing a patio slab. Water can flow freely down the "main" drain. However the water from the patio near that part of the drain is not sinking away. I think the flexible hose is blocked with decayed leaves from a plant in that vicinity. What can I use to try to unblock the flexible hose, without damaging it.
When a toilet blocked recently, I unblocked it by using warm, not hot water.
I have looked Youtube and found snake drains. I am trying to think how to improvise a snake drain for the short distance that I think the drain is blocked.
Sensible answers will be very much appreciated. Silly answers will mean that you cannot have a piece of the sponge cake I made earlier. ^_^
Speicher
Vice Admiral
Yes, that is what I thought, Rocky. If I put a question like this on the open forum as a new thread, I might get umptytwo complex answers that I do not understand.
On Tubeyou there was an American gentleman showing how to unblock drainpipes, and the drain snake looked like an expensive bit of kit. On Hamazon, however, there is this type of snake. I think it might be worth investing in a sturdy one, rather than one made of cheese. I can see another trip to the Ironmongers next week.
coffeejo
Ælfrēd
West Somerset
Speicher
Vice Admiral
Ooooh yes, wire coat hanger! I think there are some lurking somewhere. I could untwist and make a loop at the end, so as not to puncture the hose. Then I just have to remove the paving slab from over the part where the two drains join.
If I fall over into the drain, will you pull me out? I might wait for daylight tomorrow. :whistle:
Status
