martint235
Dog on a bike
- Welling
I took the sensible option today and decided to work from home.
Got a flat on the way to work. No problem, i'll just replace the tube.
However my one of my tire leavers decided to break :/
Windy and raining this morning, so once again decided not to go out into the countryside, quickly decided I still wanted to do 40 miles but without going out of the city (though I did a little bit!), so my Strava looks like I didn't know where I was going
http://www.strava.com/activities/91164090
I tried to turn my original 15 mile route from the beginning of the year into a 40 miler whilst trying not to venture to far out of the city, it is difficult without going over the same bit of road several times.I think you got lost![]()
It's unlikely that the limit screws will be long enough to do this. What you can do is leave the broken cable attached to the mech but pulled free of the shifter. Hold the mech in the appropriate position, over your sprocket of choice and then clamp the broken end under a bottle cage bolt. Fine adjustment is done with the cable tension adjuster on the mech. Three or more hands may be needed.Doh! I managed to snap my rear derailleur cable in the gear lever housing last nightHad taken an extended commute out into the Kent countryside and had to climb back up the hill from Eynsford into Orpington with just 2 gears. Oh how I wish I knew last night I could change the limiter screws on the derailleur to get it into a middle sprocket on the rear - would've made climbing up the hills a little less arduous!
