subaqua
What’s the point
- Leytonstone
there ya go less than £20
The problem is that it might be the chainrings. I will have to check as they have never been changed, ever.there ya go less than £20
Worth investing a few pounds in a chain wear indicator, that way you can change the chain before it starts damaging the cassette.The problem is that it might be the chainrings. I will have to check as they have never been changed, ever.
New chain and proper lube ordered. Total under £10.Worth investing a few pounds in a chain wear indicator, that way you can change the chain before it starts damaging the cassette.
My old main commuter is 7 speed and I just regularly changed the chain since they are very cheap, compared to 9 or 10 chain.
If I need a new drivetrain then it wont cost much.
whoops spoke too soon, sods law blustery side winds all the way homeBeen really lucky thus far this week, the wind seem pretty settled, still quite strong but not too many gusts in the morning, it has been picking up in the afternoon so get a nice bit of help home.
This time last year this headwind would have been a commute killer. Now I just revert to plod mode.
It depends on the type of riding you do I suspect. Lots of hills and sprints probably causes more wear than just pootling along on the flat without trying.Question vaguely on topic - how many miles (roughly) does a chain last? Or, more importantly, after how many miles should I start checking the chain for stretch?
You should replace the chain before it starts slippingIt depends on the type of riding you do I suspect. Lots of hills and sprints probably causes more wear than just pootling along on the flat without trying.
I have had 3 chains on my bike since I had it. Each did about 7000 miles (before it started slipping).
I dont check the wear as often as I should. I will only investigate things when something doesnt feel right.You should replace the chain before it starts slipping![]()
