I just moved to full mudguards from raceblades for precisely that reason. The rear raceblade was always sufficient but I could never decide if the front one was actually making the situation worse by concentrating the spray towards my feet. Full guards are definitely an improvement, I was just hoping for completely dry feet.I have raceblades XL's, they protect my butt really well but my feet get absolutely soaked!!!, it's where they don't cover the front wheel in front of the brakes and as a result I end up riding into the jet of water spewing from the front wheel resulting in soaked feet every time!! I might need to make a modification of some kind!
Such a thing as waterproof overshoes don't actually exist, even the expensive ones won't keep everything completely dry in anything more than moderate rain. Water will get in through the seal against your legs or through the zip/velcro and eventually water will soak through the material. Plus if your shoes are anything like mine you might have stupid ventilation holes and/or extra cleat holes on the sole which the overshoes probably don't cover and even with full mudguards you still get a bit of spray from the road. But they will keep your feet a bit warmer and shoes/socks drier than they would be otherwise and give them a bit of a chance to dry out and not smell too damp during the day.So even with full mudguards fitted I still got slightly wet feet. Wore overshoes too. Not sure if my feet sweat a lot or if it's just a battle I'm never going to win. They aren't as wet as they used to get though ie I'm not squelching around the office.
Even if i have spare socks, they'll just get wet when i put them in wet shoes!!@martint235 take a spare pair of socks you numpty.....
It was wet today.. yuckity yuk. But not a bad commute over all. At least it wasn't heavy rain and the traffic was pretty light.
In 2015, it should be possible to cycle in the rain without getting wet feet . Still as I said, the mudguards have made an improvement. I may try my sealskinz again
My cycling shoes numpty!! My socks can't get wet without water getting to my shoes.Why are your shoes wet? Don't you keep a pair at work.
Unless you put you feet into plastic bags with elastic bands at the top then you are going to have to get on with it.
Now stop moaning and keep on saving the country.
Currently saving the country! Will be saving the country from home tomorrow
Yes I have socks and shoes for work.I'm talking about spare socks for your work shoes numpty...as long as your feet are warm then wet socks don't matter.
Try your Sealskinz again. They may not keep YOUR feet dry but they will keep your dainty norvern tootsies warm
