confusedcyclist
Extra bin men? It must be serious!
In all seriousness, take care on those roads!
@Supersuperleeds There's a great video on youtube by GCN about emergency fixes for broken rear derailleurs, can't link to it at work as youtube is blocked. You may be able to adjust the chain further up the cog for those hills.Gears stopped working with 15 miles to go this morning, cable doesn't look like it has snapped. Stuck in the smallest cog at the back, had to walk up one hill. Fiddled with the screws on the derailleur and got it to go to one cog up, should be fun going home tonight.
Weather wise, the wind wasn't anywhere near as bad as I was expecting
Had the same problem on my MTB, had to manually adjust the gears till I got home(moved the derailleur with my hand, then turned the pedals by hand until it was in the correct gear)
Took me a bit to work out the problem, it would got down the gears but not up. the inner cable was seized and would not move, had to replace the gear cable and it was fine.
