Squealing Brakes
sittingbull
South Liverpool
What's copper slip?
Grease with particles of copper, particularly useful in anti-seize applications such as car wheel nuts, spark plugs, exhaust mounting bolts..... or on a bike on the pedal threads. Even if the grease dries and disappears the copper remains preventing surface cohesion. On a motorbike caliper it eliminates the resonant frequency transmitting through the caliper, effectively dampening it out.
sittingbull
South Liverpool
Available here :thumbsup:
Globalti
Er, turn the bike upside-down, remove the wheels then remove the pads?
Then take a file and file a 45 degree chamfer on the edge of the pad that meets the rotating disc. Then replace the pads in the same way they came out, making sure they click positively all the way back into their place. You need to push them quite hard. If they haven't been pushed in properly they will be at an angle and won't work well and will squeal horribly.
EltonFrog
Thank you, I'll give it a go. (gulp)
Globalti
Well while you've got them out, give them a good wash in very hot water with detergent (the dishwasher works well) and clean the disc with alcohol or glass cleaner. If the pads are contaminated with oil they will give out a nasty juddering squeal just as the wheel stops turning.
EltonFrog
Thank you.
threefingerjoe
One more thing to try as a last resort. Presuming you've cleaned, sanded, toed-in, chamfered, tried Kool Stop salmons (I like them for their stopping ability when wet, but IMO the squealingest brakes I've ever used) you might try one more thing: Make them DIRTY. I keep a small bottle of ground up cat litter (dry clay, ground to dust) and dust it on pads and rims. I've had success with this.
SpokeyDokey
If all else fails and your pads are currently 'short' road style then try some longer pads/holders such as Ashima 4 Function (I have these) or Swisstop RX.
http://www.ashima.com.tw/pad-style-selection.html
They are asymmetric and the 'tail' is longer than the leading side of the pad - this shut my squealing brakes up instantly. I think Sheldon writes somewhere about this trick - along the lines of the longer tail does not get pulled into the rim as easily as a shorter one and hence does not vibrate so easily thereby reducing/killing the squeal.
sazzaa
I changed my brake pads for the first time yesterday, and if I can do it, anyone can. Was pretty obvious why my brakes had been rubbish lately, the pads were both shiny and looked like they'd had oil on them at some point. But the replacing was fairly straight forward, once you've taken everything to bits it all becomes quite clear and is easy to put back together.
