barq
- Birmingham, UK
There's so much wheel mythology that it is probably second only to the chain cleaning/lubing threads.
Black spokes versus stainless steel anyone?
Anyway I think the idea of spokes being under compression is confusing because one thinks of them bending or pushing back through the eyelet, through the rim tape... Here's how I understand it based on Brandt and Schraner:
All the spokes start off under fairly equal tension*. When the wheel is loaded the rim deforms ever-so-slightly at the point of contact with the ground. The spokes beneath the hub are now under less tension than they were before. In normal use this compressive force will not exceed the existing spoke tension, consequently the spokes aren't entirely unloaded and the wheel retains its strength. The greater the spoke tension the more compressive force the spokes can accommodate before going slack. This is one reason why strong wheels need tight spokes.
[* Obviously there will be significant drive-side / non-drive-side differences in dished wheels.]
