hubgearfreak
simonali said:Subject diversion: anyone seen the new Crank Brothers wheels? An interesting design.
these?
i would have thought that straightening the bend out of spokes would weaken them
Smokin Joe said:I would disagree with that. Try leaning on a spoke and it will bend in half, I can't see how it supports any compression load at all.
hubgearfreak said:if you imagine a wheel with just a few spokes at the top, and a few at the bottom, ....
andrew_s said:provided we are talking about a normal wheel under normal loads.
I'm not so sure. The spoke/rim joint is a definite weak point in standard wheels. In the past I've had eyelets pull through the rim, and nipples snap (under provocation).hubgearfreak said:i doubt that there's any real benefits
andrew_s said:FWIW my personal view is that "hangs" is a better description in normal, non-specialised English than "stands".
andrew_s said:For me, I doubt that any benefits would be sufficient to override the flexibility and repairability that a standard wheel gives, however.
hubgearfreak said:i would have thought that straightening the bend out of spokes would weaken them
simonali said:That statement makes it look like you think they take bent spokes and straighten them?!!
simonali said:Plus, whenever I've had a spoke break it's been at the hub end where said bend is!
