There are ways round that, if you decide at some point to switch to canti's, as I found when I sorted the OH's Dolan. Uphanger off the fork on the front (preferable to a stem mount as the longer cable run off a stem mount can induce fork judder - DAMHIKT) and a seatpost collar hanger off the rear.
Thanks - tbh the brakes are now acceptable; the only real issues being the pain they are to adjust and small margins involved. Hopefully some cable adjustors will help with both to some extent
The novelty is rapidly wearing off my new toy after a few less-than-pleasant rides, culminating in a 24-miler last night that's the furthest I've travelled on this bike in one hit.
Unfortunately rides on the Fuji have come to be associated with discomfort - with aching in my quads (especially at the front / around the knees), the knee joint itself, back, arms and left foot - as well as a literal pain in my arse.
I've set the geometry up to be very close to my CdF (which is fine; touch wood!) and think the problem lies with the seatpost's reluctance to stay put in the frame. I did have success keeping it still by torquing it up to the recommended figure, however before Wednesday's ride to Abingdon I had cause to move it as it was a bit skewed; and obviously (in the absence of a torque wrench) didn't do it back up tight enough.
Not sure when it all happened but upon checking it last night I found that it'd sunk by around 20-25mm again
I'd spotted that the branding on the seatpost tube was very much worn off in the area that's been repeatedly exposed and driven back into the frame - now I know why! While useable I don't like having to torque the clamp down so hard so will keep an eye out for a Salsa item as I love the one fitted to the CdF.
In the past I've had knee pain resulting from incorrect saddle height, while I can see how this might also affect my back and arms. I'm a bit concerned by the foot situation; could be saddle height related but I also have a weird gait that I've compensated for in my cycling shoes but not those I wear daily.
Finally I'm not sure if the pain in my rear end is down to / exacerbated by the saddle issue, or whether the saddle is just crap / doesn't suit me. I've not compared them side by side, however the Selle item seems deeper with more curvature where it flares out to meet the sit-bones, with the Genesis item being flatter; so maybe this is the reason.
I've got my eye on a few Genesis items so will hopefully get my hands on one at some point. The Selle item can still go on the Routier as was originally planned - hopefully it'll be less critical over shorter distances and if not I guess I'll have to punt it on again.
Finally, the bike is still misbehaving somewhat in other ways - gears still occasionally ghost-shift which is really starting it grind.. I've slackened off the friction shifters a little more and tweaked the cable tension a little. If that doesn't sort it I'm out of ideas tbh.
Also the chain appears to have got a bit squeaky after only maybe 60-70 miles, when usually I get 300-400 miles before this happens. That said I've never waxed a chain that was this utterly filthy before (all others have been new / nearly new) so I'm wondering if the cleaning's failed to get all of the particulates out of the links..
I've got a load of bits lined up for purchase for this bike; however I think I'll hold fire until I know it's going to be viable before throwing any more money at it.. first stop decent replacement saddle I guess, then I'll take it from there.
