Short Cranks vs Big Cranks, Which is Better?
Which crank size works best for you?
  • Small = Below 170mm
    Votes: 5 14.7%
  • Average = 170mm - 175mm
    Votes: 25 73.5%
  • Big = 177.5 and more
    Votes: 4 11.8%
  • Total voters
    34
Wait, what? Other factors affect speed apart from cadence? Who knew??!!
So it should, by your own definition, also follow that the same process will also deliver a lower effort for the same cadence. In which case, precisely how many watts will you save by extending your crank arms by 10mm?
Then why post replies stating technicalities that are cleverly worded to rubbish the OP, whilst actually adding nothing to the discussion. The OP actually has quite a bit of experience, based on their posts, whilst you don't appear to have as much, based on your replies. You don't appear to be stupid, in any sense, so I don't understand your motivation? Boredom perhaps? Enjoy Devil's Advocate?
As for the second part, the logic does apply as you say. How much saved, or added, power output will clearly be down to the characteristics and dimensions of the rider and what they run to start with surely?
Citius
I have 'just' enough experience to realise that the OP is on a wild goose chase and that you are making claims which you can't back up.
I am not making any claims at all on this one actually. The OP is making claims based on his experience. All I did was comment about you confusing things. Anyway, let's not spoil another thread. :smile:
Citius
Except this one below, which is the one I asked you to clarify, but you couldn't. But never mind, because I know the answer already...
When you factor in the variable of crank arm length affecting the relative gearing and effort required, you are then able to change the cadence for the same effort.
er, Sheldon says you don't know what you're talking about...?
And while you're getting over your cognitive dissonance, have a read of this...
http://bicycles.stackexchange.com/q...0mm-172mm-175mm-crank-arm-length-on-road-bike
At the very least, that should tell you that none of this is as simple as you think it is.
Lifted from the page quoted:
"Yes, if you go to longer cranks without changing any of the other variables, you will have more "leverage", which is another way of saying you'll have a lower effective gear."
Hence being able to change your cadence, for the sane effort, whilst remaining in the same gear as before. That is all I said, as you know.
Thinking about the Marrin tests quoted above, they only factored in different cranks lengths and didn't test on the road or even adjust saddle and riding position at all.
Similarly, they didn't test aerodynamic gains from adjusting position when using different crank lengths.
Rather flawed really.
Citius
Do you have a degree in selective reading?
A.Z.KOETSIER
A.Z.KOETSIER
Maybe 2.5 or 5mm (165-170-175mm) change is to hard to see reasonable gains or losses with immediate effect, but I have varied my cranks by 35mm (165-200mm) and there are definite merits to both in my own experience.
Finding the one optimal crank length is not my goal. Maybe just a proportional relation of inseam and/or cadence VS crank arm length.
Surely 170mm +/- 5mm(3%) can't be optimal for everyone with rider inseams and natural cadence varying by often 15-20%.
Yes we can all adapt. but thats not why I started this thread.
Citius
It probably isn't 'optimal' - but the point I'm trying to make is that the advantage of using an 'optimal' crank size is not going to result in any meaningful difference for most people.
