Citius
Wow thats short! do you ride with a very high cadence or have a short inseam?
Let's not forget that for a given gear size, cadence is identical regardless of crank length.
How can you maintain your fastest cadence of you switch to a longer crank. Your feet will have to travel faster around a bigger circle.Let's not forget that for a given gear size, cadence is identical regardless of crank length.
At a constant power output, and constant pedaling force, you would rotate longer cranks more slowly, in a higher gear to ride at the same speed.
Sheldon says: I think people really obsess too much about crank length. After all, we all use the same staircases, whether we have long or short legs. Short legged people acclimate their knees to a greater angle of flex to climb stairways, and can also handle proportionally longer cranks than taller people normally use.
Does Sheldon spend all day climbing stairs. It normally takes me about 20 seconds to climb our stairs, I can spend 8 plus hours on a bike.![]()
Work is distance x force. If your force is constant and your distance (circumference) s greater, you are doing more work. Your body cannot just output more power for longer cranks (otherwise it would output more power for smaller cranks as well). You don't go faster if you change crank length. What gives? The variable is not power, but cadence.
You are fixing the wrong factor. As you change crank you change gearing but your body's power output doesn't alter
From what I can gather it seems situations with relatively constant cadence and resistance, like long climbs and the the Hour/TT, riders chose to increase their crank length.
Pantani (short rider) switching to 180s on climbs
Indurain (tall rider) switching to 190s in the Hour
Cancellera going up 2.5mm in TTs
In situations where leg speed and quick acceleration is more important riders decrease crank length, Like Wiggins who mostly rode on 177.5mm now he is on 170s as he prepares for Rio.
In my experience with trying different cranks (165-200mm) it has also worked out the same with my best climbing results on longer cranks and best sprints/crits and on shorter cranks. and as mentioned before i could go tremendously faster on rollers with short cranks.
shorter cranks are also more comfortable.
You claim that change in crank length has no effect on cadence. It does and you can figure this out by applying very basic physics. If you take the change in crank length to an extreme, compare say a 140mm to a 200mm crank, can you spin these at the same gear combination, at the same cadence?Not sure who you are talking to, or what point you are trying to make.
Crank length is for fit and you select a gear accordingly.
