Hi folks - just found this forum having almost gone insane with ui2 problems.  My issues seem similar to martyp but any advice is welcome.
I will try and keep this to the point!!
The bike is a Cube Agree equipped with ui2 and purchased new in Feb 2012.  No real use between Feb - April 2012 except one sportive.  Around 12 months ago, the system was completely dead.  I tried a recharge but nothing.
Took it back to LBS (they did not have a diagnostics at this point) who by power of deduction told me I had a fault battery mount.  They alluded I had got it "too wet" so I stumped up £90 for a replacement.  I was just happy it was working.
The bike worked ok for the remainder of the year.  In Feb 2013, I was away on a trg week.  On day 5 the front mech did not shift smoothly a couple of times.  I forgot about it as I finished the ride with no problem.  Later that day I thought I would check the battery charge - it was on red so I removed it and recharged.  Went back a few hrs later to put the battery back on - the system was still dead.
Another trip back to the shop (this time they had the diagnostics) and they pointed the fault to the battery.  I was sold a replacement battery and I made my point that altough I accept the battery is consumable, I did not expect to be replacing with in effect less then a years use and probably less then 1500 miles.
I got back home - fitted the new battery and nothing there.  I pressed the button on the junction box a few times and managed to kick it into life.
I did not use the bike very often until the last couple of weeks as I was trg for a race and decided to stick to my bike with "normal" gears as I had lost faith and confidence in the ui2.
When I went back to the cube, the battery seemed to die very quickly.  I noticed it was flashing at 50% almost straight away and the next morning was dead.  I had subsequently got another battery so I could swap them around.
The same process - each battery seems to charge OK taking the 90 odd minutes.  I put the battery on and within around 24 hrs it has gone from full to half and very quickly to flat.
I took the bike to an alternative shop who have the diagnostics but they could not see anything obvious on the testing (firmware updated etc)
Yesterday morning I went for a quick spin - it changes fine but after just 15 miles the front mech stopped shifting.  I checked and the battery indicator was in the red.  Swapped to the other battery and fine.  Rode home (7 miles predominately down hill so little in the way of gear change);  Checked the battery and it was ok.  Checked it again around 13 hrs later and flashing light.  Checked this morning (23 hrs after fitting) and it was dead.
I am hacked off on various counts - one that the LBS have charged me for a new mount and battery (I have been advised by another shop that the warrenty of ui2 if within normal use is 3 years?) but more so that my bike at present is an expensive dust collector.
I am due to get it back to the shop asap but it would be nice to get some opinions from here as to what may be wrong or if there are any similar issues.  All wires etc etc seem fine and there are no obvious nicks on the wiring system;
From my experience, whatever the fault is is not going to show on the diagnostic software but I just want the bike to be fit for purpose.  At present I am too nervous to go more then a hour from home.
Thanks in advance and apologies if this rambled on
