chriswoody
- Northern Germany
Even worse, they say the homebuild kit should only take 3 days or 6 evenings.
I think i would have filled the bridge with some resin and sawdust mixed together, just a thought. Great thread. thinking about doing one myself.
Loving this thread. I think the things that hold the brakes in place would be the most worrying part of the whole frame to me. I can't even begin to imagine how the front brake will be placed, look forward to seeing though.
Resist the temptation. Adding more material like that (filling up the middle of a tube) does not add appreciably to the static strength, and the extra mass can even, in certain circumstances, lead to a reduction in resistance to fatigue.It's not a bad thought ....
Not that you need it now, but there is kind of controlled-feed drill (IIRC made by Quackenbush in the USA) where you can pass the shaft of the bit through the hole and attach a reversed cutter so as to increase the diameter of the back hole. I quoted one to a potential customer once. Only about US$ 12 000 !
There is actually a way to use a 6mm through bolt caliper with a concave washer and nut. Use a front caliper on the back, they are identical apart from a longer bolt.
Just thought I’d let you know you can buy bamboo bikes ready made if you don’t fancy the build. A company here in Ghana offer them, frame only or fully built:
http://ghanabamboobikes.org/shop/
Come off it, we wouldn't have got this brilliant thread if he'd bought a ready built.Just thought I’d let you know you can buy bamboo bikes ready made if you don’t fancy the build. A company here in Ghana offer them, frame only or fully built:
That’s true, and very interesting it has been but if you bought the ready built one I suggested you’d be helping a local industry which provides much needed jobs for local people.Come off it, we wouldn't have got this brilliant thread if he'd bought a ready built.
You could make up for his oversight by buying one yourself.That’s true, and very interesting it has been but if you bought the ready built one I suggested you’d be helping a local industry which provides much needed jobs for local people.
