Reynard
 - Cambridgeshire, UK
I have a tatty but functional Shimano FD-M191. Came off a Norco hybrid with the standard 48 etc chainrings. I'll post it out if you can use it.
Cheers, will PM you
If you've got QR wheels there needs to be enough 'stub' of the axle in the dropouts to locate the wheel, all the skewer does is keep the wheel secure, you may be able to use a washer and in fact you may need a washer if the dropouts are too thin and too much axle sticks out the other side. I've had this happen but I got around it by leaving the springs off as there is a little recess the spring sits in that gave enough clearance for the mil or so the axle stuck out by.Hmm, I didn't actually look to see if there were any spacers I could take out from the non-drive side...
Another, more permanent option, is to wind out the dropouts another couple of mm. But that is really the last resort. Otherwise I can always just run it as a 7-speed - to be fair, I don't often use the 11-tooth sprocket on my other bikes.
Apologies for the condition, it was simply a strip and store spare part!Well the rain this afternoon lasted for far longer than anticipated and thus kiboshed any chance of a bike ride - I don't mind cold, but cold and wet is most definitely not my idea of fun. So I've been holed out in the garage doling out some much-needed TLC to the FD that @DCBassman sent me.
Still a ways to go with it, but it is a hell of a lot cleaner and far less rusty than when it arrived here chez Casa Reynard. The combo of Barkeep's Friend, wet & dry paper and WD40 is beginning to bring it up a treat.
I'm leaving it marinating in a good coat of WD40 overnight, and then I'll have another session tomorrow.
There are subtle but noticeable differences to the profile of the cage of this one when compared to the bike's original Suntour, so fingers crossed it will solve the clash issues I was having.
 It's nowt a bit of time and a bit of elbow grease can't solve.
 Without that to help me, I had to work it out completely from scratch - a task that wasn't helped by a few other factors.
 The first was solved by a judiciously-applied knee to the top of the derailleur while I attended to the second.
 Thanks once again @DCBassman
For some reason I wasn't alerted to new posts on the thread and was just about to ask you when you would quit lollygagging, get off your butt and do some work. Sounds like you have already. Be sure to send us some pics when it's done which should be soon.
I also need to work out why the blazes the cable won't stay put in the RD
