Secondhand Raleigh Junior Rigid MTB: lemon or worth a punt?
DCLane
I remember following that orange bike build, as I was kind of intrigued. It's totally bonkers, but utterly brilliant. :becool:
But I'm working to a fairly tight budget here, and that would be so very bye bye budget... :blush:
You never know. The whole Carlton build cost under £200 including paint as parts were sourced from eBay and lots of other places. The challenge was more in finding the part listed as an auction / low buy now price and being prepared to wait. Occasionally, as in the case of the Velo Orange bottom bracket, it was sat on a one of my club-mates shelf unwanted for years.
It depends how tight your budget is.
Reynard
Reynard
It's far tighter than I'd like, alas, as the bike looked far better than it actually was. As a result, I'm having to put my sensible girl pants on and not go bananas, no matter how much my imagination wants me to. :blush:
DCLane
Well you've got rear derailleur/hanger, crankset, chain and pedals to go - so nearly there. Looks good so far.
Note that I've never heard of there being 'sensible boy' pants, so don't own any. Just 'sensible girl' ones :whistle:
Reynard
Reynard
Still looking at options on most of those parts right now and working out which is the best way to go. Free P&P is also a bit of a carrot. :blush: The only bits I've actually got to hand is chain, pedals plus the original crankset and grips - which may or may not be used, depending on how things pan out. I've also got to factor in bars and seat post as the former are damaged and the latter is too short, wrong diameter and more than a tad rusty.
P.S. I've not heard of "sensible boy pants" either. Never quite worked out why it's only us girls who need big, sensible underpants. :laugh:
Reynard
Reynard
Had a bit of a tinker this afternoon, and have been doing some thinking about parts. It all stems from the fact that the cassette I wanted to fit is now as rare as sparkly unicorn farts, so it looks like I'll have to go with an 11-32 by default.
That will definitely mean that the existing crankset won't be ideal. Unfortunately (and unsurprisingly) stock isn't great on replacements, and in any case, the cranks are too long (typically 170 or 175). Not sure where to look for junior cranksets - any ideas @DCLane ?
Anyways, as I mentioned several pages ago, I have the original FSA outer chainring (of a triple) and cranks that were OEM on my Wiggins Chartres 26. The bike's previous owner swapped them out to something she preferred, but gave me all the original bits when I bought the bike. I put these on the Raleigh this afternoon to see how things fitted. Well, they fit and look good (they're black, so go swimmingly with the colour scheme), but clearances are very tight.
The Raleigh's BB spindle is 122mm, which is far too short really. I probably need a spindle in the region of 140mm if I'm going to go with *any* crankset other than the original. That side of things should be easily rectifiable, I think.
The outer ring I have is 46T @ 130 BCD with 5 bolts, and I'm thinking, assuming what I need exists, about building a 46-34-22 triple up from scratch (or something along those lines). I'll probably ask a more detailed question on the mechanics & repair board to a) see if this is feasible, b) financially viable and c) if so, what additional bits I'll need in order to build a functioning triple.
What do you reckon, folks?
chriswoody
Photo Winner
Northern Germany
Reynard
Reynard
Reynard
Reynard
I've been quietly following along and this is starting to look really good.
With regard to the crankset, Thorn do a range of short arm cranks, sadly though they are four bolt and won't fit your existing rings:
https://www.sjscycles.co.uk/cranks/150-thorn-10464-pcd-triple-crankset-mk2-black/
They also do a complete crankset, but it's a little pricey:
https://www.sjscycles.co.uk/chainsets/thorn-short-triple-chainset-black-443222t-155mm/
maybe someone else has some better ideas?
I've been looking at those, but they'll blow the budget right out of the water... :sad:
Reynard
Reynard
I really appreciate the pointers and thoughts guys xxx :okay: I'll take some photos of the FSA cranks and big ring as fitted tomorrow, and pop them in there.
One bit of info I should have added is that it's a 68mm BB shell.
SJS have a 127.5mm BB spindle for a 68mm BB for £4.99, so that's potentially an option at least.
