Zippy
- Camborne, Cornwall
... Basically,the tube just needs a good clean up to burn out the oxides and a few stubborn bits of Alu which won't lever out. A few days in NaOH should sort that. Must remember to plug all exits from the downtube so it doesn't find ways into other bits around the frame.
My rear wheel has looked better, but my rims are wearing thin anyway so due for replacement soon. A rub over with wetsand paper has smoothed off most of the flowering where the NaOH has oxidised the rims.
I caused some damage with NaOH leaking along the crossbar and rear wheel stays. To anyone else considering caustic soda I would just add it's essential to remove the BB and to plug any rain culverts along the rear wheel stays to prevent the solution finding its way along the frame and out through rain drains and onto your Alu wheel rims and derraileur! Just plug the BB tightly with polythene to make a seal.
Also tilt the frame slightly so the solution is running toward the saddle stem (bike upright) so when the NaOH finally breaks through it doesnt run along the crossbar and out through your nicely greased headset - mine will need cleaning out and regreasing!
Hope this helps someone else. As for me I am very tired but very happy
