I can't understand why caustic would work for me & not for you?
Can you see any difference at all when you inspect the post, does it look as though it's eating away the aluminium? Is the post wall any thinner?
Mine got very hot when I did it, does yours? Having said that, the paintwork didn't matter on mine so I plugged the BB hole & did it the right way up, it was simple to keep it totally submerged with the post cut off flush with the frame, renewing the mix now & again.
I would say keep at it, it will give in, it simply has to do, unless the laws of chemistry have been changed recently?
I can't understand this either unless the product I have is "cut" with some filler or something. The instructions for cleaning drains is 40g to 0.5 litre and I am using 80g, in fact this is a saturated solution as no more product will dissolve and sediments out.
I see no real difference after 4 days of the downtube being regularly filled with NaOH. However, when I empty the waste out there is only a trickle of black thick waste and not the 0.5 litre I put in the night before so something is happening. As the reaction takes place though the volume of NaOH goes down so the end of the seat tube is no longer submerged.
Yes, mine got very hot (didn't boil) and when I filled the tube the NaOH was frothing out which is why I plugged it to keep the solution inside.
I think now I have lost the advantage of any leverage I must either chisel the insides out or use more NaOH as you say and of course - I can pour the stuff straight down with the bike right way up tonight and just plug the top of the tube.
There's another consideration - my paint is not being lifted at all though some spills got onto my alloy rims and they were burned slightly. I wonder if the solution is just not strong enough.
I wonder if the seat stem is aluminium or some other Alu-alloy?
Stewie - did you completely burn your stem out or did it go to a point where you could lever the remainder?
