sorry, new to this. i found if you right click then select view image. ?
That does work
![Grin ^_^ ^_^](/styles/default/xenforo/smls/grin.gif)
You don't need to put any tags or similar for streetviews, just copy the url as text.
Traffic will be slowing for this roundabout anway. I felt very conscious "holding up" traffic at first but cyclists are just as entitled to be on the road as cars. Drivers need to accept they may be "held up" (though it is extremely rare for this hold up to be significant, especially in the grand scale of things - what does it matter if they get to the back of the next traffic queue 20 seconds later?).
The first thing that would concern a cycle trainer or competent cyclist is that you say you need to cross two lanes of traffic. This suggests that you are riding as far left as you can on this road, and are letting vehicles pass you in the same lane. You are entitled to the entire lane and car drivers should be expected to change lane to give you safe distance, this is what the other lane is for :thumbsup:
But why would you want to ride in, say, the middle of the lane? (Cyclists and motorbikers call this position "primary position" on the road, it is in fact taught on government approved training courses).
Well, you have a safety buffer zone on your left - if someone cuts in or doesn't leave enough room, you've got some space to escape in to.
Further, you become a part of road traffic (and not merely an annoyance at the side of the road) when you ride in the middle of the lane - other road users need to think about how to pass you safely, instead of just blasting by without a thought in the world.
It sounds like you're riding quite far to the left, closer to what we'd call "secondary" position (which is about where a car's left wheels would be, maybe 1-1.5 metres out from the kerb).
On a road like this, I would probably stay in primary in the left lane the whole way along. Easily said by a confident cyclist! It IS absolutely essential on approach to this roundabout to be in primary! Being further out will actually help you get seen earlier and allow motorists to plan ahead and pass you more smoothly too.
I would be looking to "take the lane" (i.e, be in primary) by the time I got to the board with details of the roundabout exits (and definitely before the "general hospital" titled sign).
From here I would look to move to the middle of the right hand traffic lane whenever a suitable gap appears. If you see a gap behind you, wait til the last car is passing and then start to indicate left. See what the next car behind, on the right, does. If it accelerates (this is rare!!) then you have a few more attempts before you hit the lights. Most drivers will keep their speed, in which case (assuming the gap is big enough) you are quite entitled to move across. Sure, don't force an emergency stop from the next car along but the car behind might well have to slow down or change lane to pass you, just like they are expected to change lane to overtake you when you're riding in your new, safer "primary" position along this dual carriageway! :dance:
From there, I'd look to enter the MIDDLE of the filter lane. Definitely avoid riding right against the right hand side kerb, someone might try to undertake in the same lane :ohmy:
When going round the roundabout, stay well away from the outside (kerb/give way lines) as drivers don't look there when they decide to pull out. Again, counter intuitively riding less "out the way" of other traffic actually makes you safer! [not quite so much of a problem on traffic light controlled junctions but still good practice]
It's funny, but by being more "assertive" in this way on the road - i.e strong signals that make you look confident, and use of primary position where appropriate (which is everywhere except where lanes are so wide you can fit your bike and a car in the same lane (that means at least 3 feet from your handlebars to the car mirrors) - by doing this, you command your rightful place on the road as an item of road traffic and get more respect from drivers, a safer distance when they pass, you eliminate the risk of doors opening in to your path and throwing you under the next vehice behind (when passing parked cars), you are much more visible to motorists (both from behind and at junctions) and fewer punctures too :thumbsup:
