Yep, true. Although it seems that to go hydro I’m looking at an an extra £400-500 which is well out of budget.Mechanical disc brakes, rather than hydraulic. Even the 105 version still has mechanical disc brakes.
The Triban RC520 is hydro-mechanical - which means the pistons are hydraulic. I haven't tried those, but reports I have seen suggest they give very close to the same level of control you get with fully hydraulic.Yep, true. Although it seems that to go hydro I’m looking at an an extra £400-500 which is well out of budget.
That looks like you may have been using the small chainring and small sprockets at the back? If yes the chain will often touch the outer ring and would make that "catching noise" you referenced.Went for the Cannondale Synapse Tiagra in the end and am delighted with my purchase - absolutely love it and wish I'd switched to road biking sooner.
However, one small issue I am finding is chain noise in most gears (mostly on the big chainset) - I can't quite put my finger on precisely the noise is but it is like a catching noise, as if the chain is constantly rubbing against the big sprocket. Any ideas? I've only used it about 10 times and it was brand new so needless to say I am not delighted with this aspect. I need to pop in to the shop soon but just thought I'd ask the question here in the meantime.
Also, see below picture which shows marks on the inside of the sprocket (do correct me if the terminology is incorrect!). Could this be the chain rubbing?
"Cross-chaining"That looks like you may have been using the small chainring and small sprockets at the back?
Fantastic reply, very helpful. Yes it looks like I’ve been cross chaining and so appears to be my fault that the marks are there - darn! I’ll have a read and look at YouTube, as per your recommendation.That looks like you may have been using the small chainring and small sprockets at the back? If yes the chain will often touch the outer ring and would make that "catching noise" you referenced.
In reality you don't use all the rear sprockets in each chainring, you need to keep the chain as straight as you can, larger/outside chain ring, smaller outside sprockets, inner/small chain ring. The below illustrates what is often known as 'Cross Chaining' showing the combinations you shouldn't be using, in your case fig.1 the chain could well be actually touching the larger ring and causing those marks.
How many of the rear sprockets you can actually use will vary, chainring and sprocket sizes, chainstay length, chain length all influence how many you can effectively use. Yes as in your case it is normally possible to shift into every combination, but as rule of thumb on say a 10 speed double set up 50/34 with 11-34 cassette you will probably be OK on the larger/outside chain ring using the smallest 7 rear sprockets and the inner/small chain ring using the largest 7 rear sprockets; slightly more than the example on the left but hopefully that picture helps illustrate.
There are a few examples of Cross Chaining on you tube that may also be worth viewing.
Thanks, I’ll check out the videos.It may not be the tension, it could be that the limit screw is set to high, so the chain doesn't go quite as far as it should.
You also get what sounds like rubbing sometimes when the chain needs lubrication - though that wouldn't leave the marks you are seeing on the chainring, those only come when it is actually rubbing.
There are a number of videos around on Youtube for adjusting front derailleurs, they will explain which limit screw is which, and how to get the tension right - but limit screws should be checked first.
Look at second hand perhaps?
Shouldn’t a brand new bike have a lubed chain or am I being naive? I definitely need to clean it as it has accumulated a bit of black gunk already (I’ve only had the bike for 10 days and probably done 10 rides (only two relatively long at 43km and 34km) - should it be cleaned and re-lubed that often?
I’ll check the limit screws and videos. But is this something that should be done so soon, or do I have right to go back to the shop and ask what is going on?
Possibly this, mine did this, a little tweak and all was well, it’s easy to see if the chain is rubbing on the front derailleurSounds like you might need to adjust the tension on the front derailleur a little. You can do this using the barrell adjuster on the gear cable (left one for the front). Only adjust it a quarter turn either way and see if it improves. Bit of trial and error required to see which way it goes to tighten or loosen (I can never remember!)
Hope it gives you many miles of smilesWent for the Cannondale Synapse Tiagra in the end and am delighted with my purchase - absolutely love it and wish I'd switched to road biking sooner.
A new bike will have chain wax. That's OK for starters. Use a lube of your choice, it will go black very quickly as aluminium wears off the chainrings. Wipe off excess lube with a tissue. Don't overclean it, you need oil on the moving parts, not shiny dry metal.Thanks, I’ll check out the videos.
