Nomadski
I Like Bikes
- LBS, Usually
Or at least pay particular attention to descents, and potentially dangerous points en route.  Leith Hill's downhill really needs looking at IMO.
			Agreed. Maybe we should get the French over to show us how it is done. Oh, hold on, we won't be any better off as they will be on strike all the timeThey should've never been allowed to get in a mess in first place!
I'm a little confused with what the wave time is?
Wave time open 6.51 and closes 7.21 with a start time of 8.08.
I did just under 78 miles today, moving time of around 5h30, 14.2mph average. Obviously open roads, and the traffic was tricksy in places, but little climbing and the elapsed time was rather more with quite long breaks!I refer the honourable lady to my previous answer
I read somewhere about curling your toes when you put your tighten your shoes up. When you uncurl your toes, your shoes may be a bit loose, but you have got room for when they get hot.Now I just need to figure out how to stop my feet hurting so much when they get hot and shoes tighten up!
 Anyway, I got to finally use a CO2 canister that I brought at the RideLondon expo last year. So put the valve on, screwed the canister in, pushed down and nothing, checked the canister was screwed in, nothing.
 Anyway, I got to finally use a CO2 canister that I brought at the RideLondon expo last year. So put the valve on, screwed the canister in, pushed down and nothing, checked the canister was screwed in, nothing. So I slowly unsure it until the gas can escape without the canister flying off across the road.
Oh, there's a ramp that's a sharp right before you left turn into LeithI
After almost 110km I went past the bottom of Leith Hill and thought about it to see what it would be like after that distance, but thought that I would prefer not to know
This was all the first time that I had approached Leith Hill where you turn left onto it rather than right. I like how everyone has been keeping that short and sharp incline right before it quite
https://www.strava.com/activities/343951951
I've been down it a few times and got up to a fair speed, but it never really occurred to me about doing it the other way and then about 100 meters later turning on to Leith Hill. Just to wet some peoples appetite as it wouldn't be nice to not shareOh, there's a ramp that's a sharp right before you left turn into Leith
 (Google Street View does make it look worse but it is still enough for the legs to notice and sit up.
Do you mean the one back onto the A25? If so, that was mentioned a while ago and it is a bit of a wake up call after having a few easy km's downhillAlso an extremely annoying ramp the other side
Thats what I'm doing now and probably will only to about 50-60 Km on the remaining two weekends. I've contemplated with the idea of riding down to Brighton and then as I'm tapering,, I've got an excuse to get the train backI'm actually reducing my training lengths now to around 50/60 miles as I ride 150 miles a week on commute anyway.
If you did that with a cold (colds don't just appear after 5 hours), you'll be fine as wellI did just under 78 miles today, moving time of around 5h30, 14.2mph average.
 (even if I couldn't get the wretched garmin to navigate effectively
 (even if I couldn't get the wretched garmin to navigate effectively  )
)Hi. Sorry if it has already been discussed here but having never cycled (or even driven) these roads before we are planning a recce over Leith & Box Hills next weekend. I have started planning a route but would like to avoid the A24 out of Dorking up to Box Hill. Does anyone have an alternative that is not too out of the way, or is the road not as bad as it looks? I'd like to do the hills in the same order as on the actual ride if possible.
Thanks
Thanks
