classic33
Leg End Member
Yes, Yes & No.Is 2 too obvious? I'm probably missing something.
I will run this past Miss Goodbody later, see if we can come up with a shunting solution.Shunting Solution Sought
How must the locomotive shunt the wagons, to arrive in a situation where the wagons have changed places and the locomotive is back in its starting position?
Shunt be too hard!I will run this past Miss Goodbody later, see if we can come up with a shunting solution.
Three Question Quickie
Q: Twelve. A: Six.
Q: Six. A: Three.
Q: Four. A: ?
Eggs!
Even if they are starving, natives living in the Arctic will never eat a penguin's egg.
Why not?
How Do You Do
A barrel of water weighs 20 pounds.
What must you add to it to make it weigh 12 pounds?
Sleep
What can run but never walks, has a mouth but never talks, has a head but never weeps, has a bed but never sleeps?
NoHeat?
NoIt may not be the answer on the card, but it is correct!
OK then, how about helium balloons?
