IanSmithCSE
- Worcester, Worcestershire
Good morning
The motor unit is not like a normal freehub body attached to the hub, the unit achieves freewheeling by a freehub being permanently attached to a cover plate which is screwed to the toothed ring.
If you look again at the left picture you will see that there is a wheel bearing in the cover plate that covers access to whatever pawling mechanism exists. You can hold the coverplate and drive/freewheel the hub, that is where the action takes place, not further in after the coverplate is attached to the motor.
Bye
Ian
I can't find the fault as I haven't yet worked out now to separate the freehub from the mounting plate.OK, The metal annular ring was undamaged and the three white plastic pinions in your last picture look fine - so what was the fault that you found? Pawls?
Bye
Ian
