On my cheap digital luggage scales the frame came in at 1.78kg with a bit of seatpost and the headset caps included.
Finally I thought it was time to add a couple of photos
Jeze! I started reading from the first post and was going to suggest having someone with oxy gear to burn it out but it looks like a monster has been trying to get inside the seat tube.
I have melted several stems and seat posts out for people over the years, always on crap frames that I don't want to see ever again, unfortunately yours is a nice frame.
I used a straight nozzle of 1/16" and chased it down the sawn off stump in a line, it cuts through the alu like a knife in butter and does not heat the steel enough to cause problems, the flame is moving fast enough. Once the stump is melted through along its length its easy to fish it out with a hooked steel bar fashioned into a slide hammer. On a friends mountain bike there was a very long post and I had to use a cutting nozzle to melt the entire post, the paint blackened but did not burn off.
For anyone encountering stuck alloy in
steel, avoid chisels, saws, hammers and the red mist, find someone who welds for a living. Try phosphoric acid (alloy wheel cleaner) or caustic soda, it will work if the corrosion area is not large, if that fails to budge it see a man with oxy acetylene gear and knowledge of how to use it.
