raleighnut
- One of the 'Elite'
Maybe at the point it was resprayed the rear triangle was replaced with 531c tubing which would make it a 653 tubeset.Good question.
The answer is not 100%, but probably yes.
The frame has had a respray and has a Reynolds 653 transfer on it. However, from the serial number the frame itself is end 1982/early 1983 (SB5797) and the fork in addition to the serial number has 1082 on the steerer) This suggests that it is not 653 as that was 1986(?) onwards.
The other indicator that it is 753R is the Cinelli Bottom bracket which is the SCM version.
And this is not a scientific proof, but it "rings" like 753 when you flick the top tube
Of course what I need to do is weigh the frame and subtract the weight of the stuck bit of seatpost , but it is currently at work and the scales are at home![]()
Saddens me to say it but I'd avoid Ellis Briggs.Bob Jackson, Leeds or Ellis Briggs, Shipley.
Afraid so. Took almost a year to get a frame back after taking it in for a respray. They never contacted me once and fobbed me off with excuses every time I called. Their Facebook page is full of people complaining of similar and worse experiences. Shame.Bad experience?
You're a better man than me if you can tell 753 from 531 by flicking a frame tube with your fingernail! I can tell the difference between gas pipe and 501/531 using the flicking method, but I wouldn't like to try to differentiate various butted Reynolds tubes from each other in a blind test. I certainly wouldn't be betting hard cash on it!
What sort of frame & forks weight are you hoping/expecting to see when you manage to weigh it minus the seatpost?
Just out of curiosity, how big is your SBDU frame?
Or 531c (Competition)I wouldn’t bet my house on it either
Weight wise I would be looking at 1700g or less for the frame, of course at that weight it could still be 531SL![]()
This one is marked 55, it’s at work so I cannot measure it this evening.
I still, for the moment, have the other two I have posted on here: a 60cm 753 and a 57cm 531. The 60cm is just that little bit too big and I will be moving it on soon, (hence this other one)
The joy of being Brussels based (apart from the frites, cyclocross and err the Smurfs) is that cheap SBDU bikes turn up within driving range on a fairly regular basis
Originalshinkicker on Retrobike has a blog that should help with identifying your new frame. If you are thinking about etting your bigger frame go I could be interested
Thanks, just thinking about metric / imperial seat post sizes for frames made of 753
