would have to swap out tyres, tubes and brake pads - so thinking of doing it all now and then puting them back on in the spring'If you aren't commuting then why not. Only thing is it will promote more wear on an expensive wheel set. Just swap over on wet days. Takes 2 minutes.
I probably would put them away for the winter. Although, you could just buy a second set of tyres and tubes to shod both wheels and then swap back and forth between wheels to suit the weather. Brake pads don't take long to swap, I swap mine all the time.
i got 3 sets of tubes and tyres - one set on the sabbath, one set on the defy 4 and one set on the jamis 29erIt never occurred to me that someone might only have one set of tubes and tyres
All my wheelsets are shod with something all the time. Unless broken.
There are those of us that have to think twice about getting a spare tube let alone a spare pair of wheels.It never occurred to me that someone might only have one set of tubes and tyres
i'm pretty new to all this - so building up my arsenal slowly but surely - my other love is golf, which also costs a shed load of moneyFor the winter?
I swap wheelsets 6 times a week. It is part of pre ride prep like pumping up the tyres or getting dressed
As to the Zipp's - given the hub's reputed fragility, I would avoid riding them for prolonged periods in bad weather - I generally save my best wheels for best, and ride crummy wheels on bad weather days. Not religiously but as a trend.
will put them away - and then when they reappear in the spring i will shod them with Conti 4000s and some super tubesI probably would put them away for the winter. Although, you could just buy a second set of tyres and tubes to shod both wheels and then swap back and forth between wheels to suit the weather. Brake pads don't take long to swap, I swap mine all the time.
There are those of us that have to think twice about getting a spare tube let alone a spare pair of wheels.![]()
give or take a few more hundred of pounds - merlin are the cheapest at 1500 for the wheelsetI don't think it's disproportionate for £1200 wheelset to have it's own rubber. He already has the wheels, this is not a financial discussion.
