classic33
Leg End Member
When there's sufficient pheasants requiring plucking.When will the pheasant plucker turn up?![]()
is there a connection with the woodchuck season?When there's sufficient pheasants requiring plucking.
Along the lines of how many pheasants could a pheasant plucker pluck if the pheasant plucker was plucking pheasants. No.is there a connection with the woodchuck season?
You meanI take it you haven't heard the one about how much wood could a woodchuck chuck if a woodchuck could chuck wood?
Or the earlierHow much wood would a woodchuck chuck if a wood chuck could chuck wood?
And an earlier answerIf a Woodchuck could chuck wood, how much wood would a Woodchuck chuk?
I suggest you ask a pheasant plucker.
You mean
Or the earlier
If you tip a robot-waiter, does it fall over ?
I heard the sound of a small aeroplane today. On looking up at the sky it looked like it had one engine, not two. It didn't seem to be going fast. In fact it was moving quite slowly. My thoughts were what is the minimum speed an aeroplane must travel at to keep it in the air? 🤔
Pretty slowly many micro light aeroplanes travel quite slowly and if into a breeze could fly backwards over the ground!
https://www.google.com/url?sa=t&sou...QtwJ6BAgSEAE&usg=AOvVaw0uXJaIOrqN4HkOTk3antOs
Surely in most cases the weight, width and length of the plane will determine how much speed and power is needed to keep it in the air? 🤔
