Ming the Merciless
There is no mercy
- Inside my skull
Could you survive parachuting through a thunderstorm?
Egg Foo Yung ?
Church Street Chippy very nice
Is she Doris Stokes?
To be fair if you're an elite athlete you are balancing on a knife edge. Look at Radcliffe - she was doing a huge mileage and spending almost as much time on her physios table to keep her running.
You want to do as much training as you can cope with without breaking yourself.
Trouser fasteners, if you've eaten too much.What gives?
"In a thundercloud, your chances of being hit by lightning are higher than on the ground because your wet body presents a more conductive path than the air around you. Nearby lightning bolts will jump to you, then continue to the ground."Could you survive parachuting through a thunderstorm?
"In 1959 a US Marine pilot called William Rankin ejected from an F-8 Crusader fighter jet directly into a storm. It took him 40 minutes to reach the ground and he suffered frostbite and severe decompression injuries."As long as it opens![]()
She's very clued up on star signs, but not into the paranormal stuff. Are they not similar though?🤔
Only possible, in the first place, if you have photosensitive epilepsy, and even then you'd have to match the frequency of the seizure trigger frequency.Walking past some high railings in very bright, very annoying, low, almost blinding sunshine yesterday, I had that horrible flashing affect as I moved from sunshine to shade per split second. I covered the affected side of my face with my hand to stop the flashing. It made me think about what I heard years ago that this could bring on an epileptic fit, if you are epileptic (obviously). Is that true, or just an old wives tale? 🤔
