Perils of buying 2nd hand and goings on in my garage
biggs682
biggs682
Northamptonshire
And just like that the bottom bracket is all out and I have found the reason for the free play
So hopefully a clean and some new bearings will sort it
Ajax Bay
East Devon
Yes I saw the Biopace sticker on one of the earlier images.
Value there, with the surface rust abraded away.
I'd just bang in a Stronglight (or one of my stock of UN-52s).
That 'Golden Virginia' tobacco tin has seen a few 'goings on' (in your garage).
biggs682
biggs682
Northamptonshire
Yes the 'Golden Virginia ' contains quite a few different freewheel removing tools and certainly has seen some action in various owners garages.
Must admit the crank and both mechanisms could quite easily adorn a road bike easily.
raleighnut
Yep as long as the shaft and cups are not pitted a couple of quid on new bearings should sort it, one tip (though you probably know it) is plenty of grease.
I seem to remember the BB in mine went south fairly quickly and Roy Pink in Newport Pagnell sorted me out with a proper cartridge BB.
Cartridge ball bearings are crap however bikes under 10 years old with 'cup and cone' bottom brackets suffer with woeful case hardening that flakes and pits as they're made on the cheap.
biggs682
biggs682
Northamptonshire
Yep as long as the shaft and cups are not pitted a couple of quid on new bearings should sort it, one tip (though you probaly know it) is plenty of grease.
These should clean up well enough for what I need it for .
biggs682
biggs682
Northamptonshire
Bottom bracket has been fully overhauled , found some loose bearings to replace the broken caged ones on the drive side .
Spindle was good so a quick clean up and all rebuilt.
Whilst the crank was off gave it a good clean.
All back together
Next job is to service the headset and drop a set of 700 wheels in to work out what drop I have and to see what calipers I have or can get to suit.
slow horse
Don't mind me, I just came here to gawp at someone who knows what they're doing.
Your picture prompted me to read up on boron. It doesn't appear to be a suitable material for bike parts.
biggs682
biggs682
Northamptonshire
The Diamond back left the garage yesterday hopefully the new owner enjoys it.
On this morning's ride I had a rear spoke go pop on me quite a regular thing on this rear wheel for some strange reason. Once home found a new spoke of suitable length and set about fitting it, new spoke wouldn't scree in to old nipple , so stripped tyre off and found a pot of nipples and found one that would screw on to spoke and then built it all back together , ready to go.
