Octet
So you are stating that none of the 43% of head injuries admitted by the NHS from simple falls could be prevented by this helmet?
This helmet would most likely prevent the large majority of injuries sustained through simple falls, at no point did I deny this.
"Reductio ad absurdum" was in response to your comment that everyone should wear one. You are blowing the entire argument out of proportion by using excessive exaggeration in an attempt to make it sound ridiculous.
2870382 said:The better than nothing idea only applies to cycling but not walking or driving? Why is that?
Because if you read my other point, the injuries and risks are on average going to be less severe if you are simply walking. When driving, you are going to be exceeding the forces that the helmet is capable of withstanding (however the airbag in the case of the car acts in the same way as the helmet does... would you drive a car without an airbag?).
Tripe!
The research shows that a helmet that is badly fitted can double the severity of a head injury!
We are not talking about badly fitting helmets, we are talking about the helmet itself. Assuming that it is correctly fitted, it will provide greater protection than nothing in the majority of cases.
