Fab Foodie
- Kirton, Devon.
Now, just a thought....If i am making Cottage Pie or Spag bol I normally use mice from the butcher
previously I would get it from the supermarket - generally the most expensive version - 5% far rather than than the cheaper 20% fat
using the mince from the butcher there is not enough fat coming out of the meat for my wife to make gravy
using the best supermarket meat she has loads
same with sausages - loads of fat comes out of the premium supermarket version
butcher - naff all
and the stuff from the butcher tastes much better
and is cheaper
but all the advertising tends to point us to the supermarket - and CLEARLY they premium versions just MUST be better
pity we don;t have a greengrocer on the high street - I just feel lucky a butcher has survived
Salt is very important in making meat products. In my experience, UK manufacturers of sausages and bacon are right at the lower end of the functionality range which means poor water and fat binding. Butchers tend to have higher salt contents and more stable products...less water and fat seepage.
It’s a perfect case in point where a certain level of salt is required to maje the product work properly. Cheese is another good example, especially blue cheese where salt level is crirltical in ensuringbthe correct microbial and fungal microflora. You can’t make low salt Stilton.
- usually for jams & marmalades, that's 1 part sugar to 1 part fruit. I think that's about the lowest you can go without encountering problems. I seal while still very hot, and stuff keeps for years in a cool dark place.
Breweries and bakeries were usually next door to each other.
