IanSmithCSE
- Worcester, Worcestershire
When I first heard of the 525 replica a few years ago I was excited, than I saw the specs and thought, if this was painted in any other colour I wouldn't even be looking at it.
Then when the 753 replica was announced I was wow, get the credit card out. Then the details on complete bikes were announced and again I thought its not really interesting. Lots of Dia-Compe, a brand that was always bottom end in my mind, 10 speed non indexed down tube shifters, I sort of get the point but also see it as proving a point and a frame made in Taiwan. If the frame wasn't in Raleigh team colours then I wouldn't even have looked.
I suspect that Raleigh 753 frame is heavy as it needs to support the older rider who bought it to remember their lighter youth, interesting to note that it appears to have been welded not silver soldered in part, even approval of this from Reynolds.
A while back BJ had a rant on their site about how 525 was introduced to replace 531 as 531 couldn't be TIG welded and how they wouldn't use it as it offered no benefit to the cyclist.
I'm not convinced that 753 is really anything noticeably better than 725, I did a bit of research on metals and it is seems to be possible that certain batches of 531/753 and 525/725 could be almost the same metal. I was brought up on 531 is manganese molybdenum which is better than chrome molybdenum but once you accept that the metal to make 531 was bought on the open market and there were differences in composition, the magic goes.
In the table above I have 3 versions of 531, each using Manganese Molybdenum steel with varying levels of chromium, the numbers are mid range of the averages and both the 531 with chromium may have zero chrome as it is a side effect.
Keith Noronha, MD of Reynolds has openly said that 531 has been different alloys over its life.
So again I lost interest as I see a £1,500 frame that is not what I dreamed to be.
This seem to suggest that even I don't really want a new steel frame, even though I may need one. Unnoticed until recently I found quite a bad rust spot underneath the front mech's mounting band.
If this does prove terminal I will likely ride my plastic bike more as I already have it and get a beater for the shopping duty. I might buy a Genesis steel frame but I won't be coughing up £2.7k on a 525 steel frame from Argos (https://argoscycles.com/new-frames/reynolds/)
The only thing about Genesis frames is that I am confused about what the forks and stays are made of.
Bye
Bye
