pswaverley
- Glasgow
Hi I have done 4 cycle tours the last being in June where I spent 22 days on the road. In my tours I have used 2 bikes both hardtails which if you are touring with light loads are fine. But on a long tour I would go for a touring bike with the 4 panniers set up. On long tours you will pick up extra weight, you want less gear piled up on top of your panniers as possible as that means less time stripping them off to access them. Also for using trains ferries stripping loads of items of is a nightmare. I am a big fan of front suspension bikes but once heavy loads are on the susp ension is non effective so go with rigid forks. Tyres I did New Zealand's South Island on 2.35's enthusiasm got me round, the last tours have been continental 2.2's but I will run with a 2.2 touring tyre for future tours, wide enough for absorbation but heavy weights on a bike do provide good insulation against rough surfaces. I prefer flat handle bars with bars at the end really provide a comfortable position. Gears 27 minimum there should be enough to get you up most hills don't run under this you will need them. Also with tyres make sure they are properly inflated you will do a lot of damage to your wheels with extra weight on your bike and under inflated tyres. You can buy a decent touring bike on Gumtree etc Try and go for a good brand and I would recommend a steel frame, as you will gain extra weight on any tour. Touring is superb but it takes a while to get into the tour and the extra weight but once passed that it is an amazing way to get around. So a 2nd hand bike take it out do a small tour to get used to it. Remember apart from the frame all components can be changed and upgraded to suit your individual needs. Also when touring either get a dynamo for charging or carry a small solar panel. Essential for running with a tent
