Smurfy
Naturist Smurf
- Smurfette's Kitchen
In my experience, the noise gets worse the more grit is embedded. It's something that correlates well with wet riding, and off road riding (where there is usually puddles and grit abounding)
Low maybe, but enough to embed chunks in the pad. Remove a piece carefully one day and you'll see that it doesn't look like a piece of swarf created by a machine tool or sharp instrument. It is lumpy and crumbly.1. I'd suggest that the transfer of aluminium to pad under the conditions you describe is very low.
2. What you describe will not lead to the grit on metal sound, which I think is what the OP means when he says his brakes are noisy.
3. Although the high local temperatures result in a small amount of material transfer, 'crystallised rubber' will never result in the same highly damaging abrasion as grit, for the simple reason that only materials significantly harder than aluminium are able to deeply scratch or seriously abrade the rim.
4. Your comparison to extrusion is not a good one, as extrusion requires enormous pressure as well as high temperature.
Your explanation for the alu pick-up and noise is grit.In my experience, the noise gets worse the more grit is embedded. It's something that correlates well with wet riding, and off road riding (where there is usually puddles and grit abounding)
Cos they're cheap and they have a huge marketing/sponsorship budget to support?Why would specialized use unsuitable blocks, this must surely be a common issue.
@Yellow Saddle I'll try and get some pictures tonight. I think that it must be the blocks as you suggest as both rims are scored and I'm not riding in any different conditions to my old bike.
Why would specialized use unsuitable blocks, this must surely be a common issue. I've now ordered some koolstop blocks to see how they fare, I might take it back to the shop at the weekend to see what they say .
The stuff I'm talking about and fish out of black brake pads is definitely aluminium. Further, I never find any other material in there, only alu. Perhaps you think otherwise and then a macro photo of embedded grit as you describe will bring resolution to the issue. So far I only find metal.
I have explained that the alu's temperature rises and therefore something softer than alu at room temperature does gouge it out as described. Examine the scratches on your rim with a magnifying class and compare them to a scratch you put in there with an awl or even rough sandpaper. You will see a difference at the fringes. If you thin the brake pads subsequently buffed the fringes, try doing that by putting a scratch on a rim and them applying the brakes. You will see that it does not change shape like a heat-induced roll-up.
As for the pressure, I think localized pressure at the hard point in question is sufficient to do the job.
I'm not convinced that a polymeric or rubbery material can transform to something hard enough to damage aluminium. The only transformation that would fit that description is carbon to diamond, but we know that synthetic diamond production requires extremely high pressures and temperatures, or other special conditions.Your explanation for the alu pick-up and noise is grit.
Here's a slight enlargement of the OP's brake pad. Point out the grit that caused the problem.
Here's a snip of the picture I posted earlier of a rim damaged by a brake pad. Have a look at the shape of the grooves. Some are intermittent, others are continuous, but none display a typical scratch. I don't have a better photo unfortunately since all my rims are on Koolstops. Perhaps @Globalti still has his scraped rim in the garage? Perhaps the OP has a nice macro camera and can show us what his rim looks like.
Shimano ultegra pads are noisy, dodgy in the wet and chew through rims in about 12 months.
Koolstop Salmon or SwissStop Green cure the problem
I want to resurrect this thread but I doubt you are still around.I'm not convinced that a polymeric or rubbery material can transform to something hard enough to damage aluminium. The only transformation that would fit that description is carbon to diamond, but we know that synthetic diamond production requires extremely high pressures and temperatures, or other special conditions.
https://en.wikipedia.org/wiki/Synthetic_diamond
The 'lumpy crumbly' description is perfectly consistent with a piece of grit creating quantities of aluminium powder, which is then loosely compacted together with brake dust. Of course the particle of grit that produced the aluminium powder may be elusive, as it only takes one grit particle to produce quite a lot of aluminium powder, and there is no guarantee that the grit particle will wait patiently for you to inspect the brake pad, rather than dropping out while riding.
I've nothing I can contribute that might help answer the question, but I'd just like to note that I'm not at all surprised by that - friction can indeed cause enormous temperature rises on the tiny tiny tiny local scale.II have also ascertained that the flash temperatures at the asperite level during braking is about 600 degrees C.
Everything is flat, at some scale :-)Yebbut, the Earth is flat, that's what my teachers told me, so it must be.
BB
