1850 watt hand-held, 12.7 mm cutter, 20mm diameter guide bush, and a 6mm thick full size template made of MDF.Using a hand-held router or an overhead ?
Either glue a 'sacrificial' strip on either end to help prevent spelch then plane that off or clamp a couple on if you have a long sash clamp.1850 watt hand-held, 12.7 mm cutter, 20mm diameter guide bush, and a 6mm thick full size template made of MDF.
Still t-shirt, shorts and sandals here.We are returned from a very pleasent 7 mile walk. Felt good to have a fleece on and stride into a slightly chilly breeze. After the heat and sun of the last few months, Autumn feels good.
Still t-shirt, shorts and sandals here.![]()
My neutral expression is very much RBF, regrettably.You aren't looking very grumpy, Greg.
Which is good, but not conducive to striding out with any kind of energy.Still t-shirt, shorts and sandals here.![]()
Yes, my screen saver face is often interpreted as miserableMy neutral expression is very much RBF, regrettably.
and, I admit, I can be a bit tetchy, at times, when provoked, by fools. Whom I don't, and won't, suffer gladly.
Just tried the Cotswold Dry Gin. Very nice. Had to buy a bottle.
I'm about to roll my eyes and move on. There's not much more to say!BTW Jo, good luck with your discussions elsewhere on CC. I've given up arguing with Capt Blimp. He speaks the same language as us but seems to inhabit an entirely different reality.........a reality I do not and never will comprehend.
