Ming the Merciless
There is no mercy
- Inside my skull
Ahh, but 'back in't day' 'when men were men', touring on single speeds & three gear derailleurs were the norm - !![]()
As was walking on hills
Okay, I have to admit to wimping out and getting the occasional lift home. :-)Oh and Thru-Axles, brilliant things that guarantee perfect wheel alignment every time.
With Q/R it is just flick/flick and the bike is in the car and at the other end it is just as easy.
No, oh that's unfortunate when you realise that the thru axle fell out and is in the car boot a mile or two up the road.
Built in USB Chargeable Battery instead of Changeable Batteries on Lights
Yeah I know Dynamo (and oil lamps I presume) came earlier but I prefer a light I can change the battery on myself.
Then with disk brakes you have to faff around lining the disk up in the caliper to prevent rubbing as you close the lever.
Never had that issue in 22 years of running disc brakes and QR.
Your not the first person I've heard say that, so maybe it's not a universal issue. I've only ever owned this one bike with hydraulic brakes and Q/R.
Also my back wheel goes back in no problem at all, it's just the front wheel, along with the lawyers lips, is an absolute pig to get in. For some reason it requires getting the lever to close almost 80%, then gently eyeballing the rotor in the caliper and pushing the wheel as you close the last bit. Get it wrong and the pads will rub the disc.
Could well be that if you were to measure everything with precision tools, that something is out of whack slightly, I really don't know. Maybe it is just my bike and no others, but it really is a pain in the back side.
I dislike disc brakes on road bikes, OK on MTBs (in fact I own a Mountain bike with disc brakes) but on a road bike they're fugly
first question is, is my 1988 bike vintage ?
I like the concept of disc brakes, but what are they like for maintenance for someone who rides all winter
I dislike my rim brakes on dirty winters days when they grind the rims away, just hate that noise, but would I be better off with discs, or do they come with their own set of problems?
Good evening,
The one thing that I could be persuaded is a loss is a frame tube large enough to take a down tube battery so that I could have an X35 (or similar) ebike.
Imagine this as an ebike, the hub motor would almost be hidden by the large sprocket... and then ........ imagine it again with a proper fork and head tube.
I went Di2 (10 speed with lots of wires) on my new old stlye 753 frame and as most new electronic gears are wireless (to a greater or less degree ) it is even easier if buying new.
Although I don't have the desire (or the nerve) to try it,
you may be able to glue some disc brake mounts to a steel frame.
I think steel is implied by old,
Old bamboo will have rotted away.
Oh no it won't, m' mate has one he made in Vietnam in the early 70s
I am only semi joking;
That way you get the pleasure of a really annoying shriek for about 1 wheel rev every time the pads get wet and you get to pay the LBS £54 3 times a year for 4 new pads and these are just Tiagra level (okay about £35 on line)! Gotta love this progress thingie.
But I do like the feel of hydraulic brakes, if only they made hydraulic rim brakes (but isn't a rim a disc without a hole, a-la Polo mints?) as I am not sold on thru axles. Actually I do remember talking about them in 1970s and we all felt stupid, why would anyone do that? I was too young for it to be pub talk but......
Bye
Ian
With Thru-Axles the first thing you do on removing the wheel is pop the axle back in the frame and nip it up finger tight..
I can see how this might happen but it's probably only going to happen once to someone.That’s the first thing you should do, but it isn’t by design something you have to do so many times, many people have left their thru-axle at home or on the ground or whatever.
