Bonefish Blues
Banging donk
- 52 Festive Road
Typically 'just before' anyway chums
It seems most brands have had carbon fork recalls but from what I remember reading the carbon fibre blades bonded to a aluminium steerer was a much more common failure than the full carbon fibre forks maybe 70% to 30% as an impression but the bonded forks often took time for the bonding to break down. Of course carbon fibre forks are hand made, layered etc so its something which can be great 98% of the time but then 2% fail which is enough to merit a recall. As a heavy chap I don't even consider carbon fibre but because of how forks fail and collapse the structure of the bike they are a lot more dangerous than carbon fibre frames. Personally I'm a huge fan of steel forks which have incredibly low failure rates and not bike weight obsessed so for peace of mind go steel.
There's a long history of lightweight performance bicycle forks causing injury and even death in fact there was a British manufacturer Viscount that used aluminium forks that were called death forks years ago with a steel frame.
The benefit of steel forks isn't just their strength and durability but they give good notice of when they are going to fail and if you get the fork design which has tapered tubes with a slight curve they offer good a level of flexing for comfort. Some modern steel forks are straight blade and don't really flex. They might be a bit lighter though.
Carbon fibre often has the cheapest nastiest manufacturing as its so labour intensive. Quest Composites who manufacture for Trek and Canyon and likely many other brands too have horrible cramped conditions and you can see clearly in this factory image from Quest themselves that the woman in the foreground is not wearing that protective hat properly and any dust or dirt that gets into the carbon fibres is like a cutting blade as the forks flex.
lol If you think those are "horribly cramped conditions" I can only assume you've never seen the inside of a factory before.It seems most brands have had carbon fork recalls but from what I remember reading the carbon fibre blades bonded to a aluminium steerer was a much more common failure than the full carbon fibre forks maybe 70% to 30% as an impression but the bonded forks often took time for the bonding to break down. Of course carbon fibre forks are hand made, layered etc so its something which can be great 98% of the time but then 2% fail which is enough to merit a recall. As a heavy chap I don't even consider carbon fibre but because of how forks fail and collapse the structure of the bike they are a lot more dangerous than carbon fibre frames. Personally I'm a huge fan of steel forks which have incredibly low failure rates and not bike weight obsessed so for peace of mind go steel.
It was a new bike.
Happened to George Hincapie a few years ago. Apparently it was an aluminium steerer bonded to a CF fork so the join was the weak point.
View: https://youtu.be/7ZiZy0pm2T0?si=Fyu0qu7z--V9asJ1
I suspect that in terms of the forces being exerted on the frame there is a big difference between a professional giving it full beans on the cobbles compared to a recreational cyclist on his first ever ride.
completely irrelevant. They have public and product liability insurance, the claim being handled by the insurers, whose first course of action is always to deny liability, which they have done. it will either come to court in the fullness of time or more likely be settled before then.
Typically 'just before' anyway chums![]()
Just before is right. I was due my day in court when the measly offer came in which I instantly rejected out of hand. The opposition made their final offer on the morning of the court case and I've always regretted that decision ever since. I was on solid ground and should have seen it through.
So what? I would do this test particularly thoroughly on a new bike.
From my reading of the situation their insurance sits with Chubb. They have very deep pockets ,
but their defence is that firstly the forks were not defective u less you can prove otherwise and secondly if they were defective, they were purchased from a third party supplier in china in good faith, so sue them not us.
Suing a Chinese firm would be all but impossible.
