mudsticks
Obviously an Aubergine
What sort of oil? I'm thinking Castrol GTX isn't it.
Definitely, isn't it..
I Look forward to the pictures
In the UK??? We're lucky if we get direct sunlight for a DAY or two!mudsticks said:Gosh, it's so simple, I reckon even you could manage it.
Basically you put your cleaned chosen 'erb, in a decent quality oil.
Leave out in direct sunlight for a week or two..
Turning regularly - perhaps even daily, if you're of an interventionist mindset.
Then store normally until ready to use for salad dressings, bread dipping, or rub it in all over, post bike ride embrocation.
In the UK??? We're lucky if we get direct sunlight for a DAY or two!![]()
You plonk your flavouring in the oil and leave it for ages. It's common to do this with oregano, roseamry, chilli, garlic, whatever you want really. If you're using it for salads then use a good quality virgin oil. If for cooking, then cheaper (non-virgin) will be fine.How does one make infused oils?
I'm jealous of your dymo embosser and I don't even know what it is
I rescued my dad's when clearing his things.
That label must be decades old.
It still works.
As you can see, if you make a mistake, you don't find out until you have finished the word!
The problem with those Dymos was that the sticky stuff gave up the ghost pretty quickly. You need one of these.....but buy no-name bootleg tape cartridges if you want to avoid bankruptcy.Aren't they just the greatest??
They bring out an overwhelming, nay irresistible, urge to label anything, and everything..
However inane, and pointless![]()
They make very good herb, and spice jars on account of the darkened glass.
For a nice retro 70's feel, print out the contents on your dymo embosser, to stick on your jars, and then screw the lids* to the underside of your kitchen cabinets.
* AFAIK this activity was a prerequisite of being anyones grandpa-with-a-shed before the 1980's.
The same method has been lovingly recreated, as a tribute, here in the barn workshop.
It still works.
This is risky. Herbs can carry botulinum spores which given time under anaerobic conditions (which oil does) and a low pH (which oil has unless it's been acidified) can activate producing toxins in the oil. If this is consumed without raising the temperature of the product to a level that will denature the toxins, the effect can be devastating.You plonk your flavouring in the oil and leave it for ages. It's common to do this with oregano, roseamry, chilli, garlic, whatever you want really. If you're using it for salads then use a good quality virgin oil. If for cooking, then cheaper (non-virgin) will be fine.
