swee'pea99
It's a good idea, and I'd do that if I could. Unfortunately the lock's locked in a horizontal position, totally unshiftable. And I don't think it's been glued. My guess is that it's just worn out...something's gone a bit wonky inside.Have you tried tapping the lock with the key slot empty & facing down. I ask only because you said the key doesn't seem to go in the whole distance. Any plastic that you're aware of in the lock itself. If not heat with a lighter & repeat the tapping & see if anything falls out.
Has it been glued up?
