mrmacmusic
- Tillicoultry
I'm no expert but nearly freaked when I first read the MS battery issue a few years back. You need to keep an eye on them when charging, and check that they aren't left on anything that can burn. Flatting them kills them, unless its a quality expensive protected cell.
Bear in mind these cells deliver 3.7v and can whack out over 5 amps - compare that to an AA. This is why you need care.
That said, one MS battery died over the first winter as both were left out in the greenhouse as I wasn't having them near 9 bikes. One failed, one is fine today 3 winters later, slightly less capacity. I also have a new one from last year which is fine. TBH, charge them regular, away from combustables, so garage floor etc or in a tin box. They can only go bang under charging or short circuit, because they can kick a good electrical punch, even AA's can make a mess if short circuited. I've got over the initial panic now. If they show charged too soon, then test on the light, they will go blue or red fast. Time for a new pack ! Protect the battery from water ingress.
Also, I'm charging my new battery pack on the office desk, which sounds like it might be a bad idea?
