Lawnmower - fix or replace ?
Profpointy
I would totally be tempted to patch it up, as mentioned above with a few options, some sheet metal and a pop rivet or 30
A good opportunity to learn some skills!
^this. Patching with bit of biscuit tin should be within anyone's skill level, providing it's just a few holes. It's not as if you have to preserve the elegant lines of an e-type jag's wing.
One hint, if drilling sheet metal never, ever hold the sheet in your hands. If the drill sticks, which is very likely, you'll slice your hand very badly.
Salar
A fish out of water
Gorllewin Cymru
Interesting,
I've an Izy, just needs a new plug and spark plug cap. Too heavy for the wife and a bit of a lump on the slopes even for me, so it's not getting used, might give it a service and put it on fleabay.
We went for a battery rechargable mower and strimmer a few weeks ago, I was reluctant at first not thinking it would have much poke as we have a big garden with some slopes.
In fairness if you take it easy it does the job on a full charge and is so light I can whizz around the garden a lot quicker than the petrol mower.
Also the wife can use it ^_^
Dave 123
You need to speak to the Head Gardener... @Dave 123. The first thing he'll probably do is tell you to get a cylinder mower...
@pubrunner - May I suggest purchasing a cylinder mower?
As @User9609 says, it pays to clean it. Our rotary mower gets cleaned after every use.
I've never changed a deck, but if it costs £100 and the engine is still good then that's got to be better than an electric one I'd have thought.
CanucksTraveller
Hertfordshire
[QUOTE 4793143, member: 9609"]It pays to clean them properly at the end of the season and give them a lick of paint- this one is over 30 years old[/QUOTE]
I'd happily pay £100 or more to avoid 30 years of cleaning and painting lawnmowers at the end of a season. I sling mine in the garage never knowing if that was the last cut or if there are more to come. Do you work full time, out of interest?
Globalti
I avoided the rust problem by buying a plastic, mains-powered rotary mower, which is fine if you've a small lawn. It gets almost zero maintenance and just keeps coming back for more, year after year. Occasionally I remove the blade and sharpen it with an angle grinder. It behaves impeccably except when it decides to chuck out a stone, which smacks into my patio doors causing the glass to shatter into ten million pieces.
Electric_Andy
Heavy Metal Fan
Plymouth
Dammit, wrote a whole piece on metal and pop rivets but I see was beaten to it! Yes, patch it up. Wickes do galvanized metal sheets for £5.50.
It's like shaving; a petrol mower goes through first time like a good quality razor blade. With electric it tends to skim over half of it meaning you have to go over it in a circular or linear fashion. Petrol also makes much better stripes as they cut better and tend to be heaver.
Heltor Chasca
Out-riding the Black Dog
I sold my 13 year old Honda Izy for £8 less than I paid brand new, but I do look after my kit. Scrape the grass off every clip as it just holds water and corrosives in the rotting muck. You will be surprised at the current prices. They come from France btw.
You have a tough decision, but to give you a clue, quite a few manufacturers mount Honda engines onto their decks which are secondary in priority to the actual engine. I bet it starts first time every spring, every year. They beat Briggs & Stratton hands down. And if you have to start a cold engine every day like I do, you will vouch for Honda without blinking an eye.
All my new big, industrial mowers have plastic decks. Streets ahead of steel or alloy decks.
Forget electric. I'd rather have piles.
classic33
Leg End Member
This kind of thing . . . ?
More this
pubrunner
pubrunner
. . . And if you have to start a cold engine every day like I do, you will vouch for Honda without blinking an eye.
Yes, mine has always started fine with no problems.
Sadly, I can only find a steel replacement deck for my mower, but as already suggested, I'll put some protective paint on it beforehand.
