Milzy
25 mm.What size tyre?
Can't hear it slosh about in my tyre but my hearing isn't the best - so I am told.
I think Shane Miller has 60psi and he’s a bit heavier than I albeit not a lot.
Are you using the racing sealent as opposed to most other types desisned to go throgh the valve?It's the only method I have used in 5+ years of running tubeless, no problems so far.
No normal Stans, but I have used Peatys solution that contains lots of bits, I didn't know there was different Stans so I may have trouble using it.Are you using the racing sealent as opposed to most other types desisned to go throgh the valve?
Just looked on their page & it says 80psi. I’ll adjust tomorrow & see if I can feel any benefit.According to bicycle rolling resistance review at 80psi the tyre has 9.9 watts rolling resistance and 11.6 watts at 65psi based on a 25 tyre. Therefore you are giving up very little to run them at 65psi so I can't really see much reason not to run much or at all higher.
I bought some 'tubeless ready' or '2-way' campag rims and have had tubeless tyres on for a while. The rims have no holes for spokes and so are sealed on the inside. Apart from the valve hole of course.
I read that tubeless ready ie 2-way rims are designed differently where the tyre seats to conventional rims in that the shape of where the tyre sits keeps the tyre in place if you do lose air. Whereas on a clincher rim, in the event of a sudden loss of all pressure, there is little to stop the tyre from coming off. Only what I read so I can't say from personal experience.
Its not just on a converted clincher rim that a tyre can unseat but also on some tubeless ready rims (including mine) because of how they are designed. I have also heard of tyres blowing off at higher pressure. If I was buying rims now I would be quite careful with the rim profile or maybe go for Mavic tubeless rims. As it is I will use what I have.
though.On MTB's it's common for the tubeless tyres to 'leak' through the carcass at first. I've not bothered as I do swap tyres round. As for tyres coming off (burping), that can happen, possibly more so with MTB's running low pressures (the advantage of tubeless - you get away with much lower pressures for better grip).
That's why I had to replace the valves. It got harder and harder to get air in .
Continental recomend 80 psi for 25s. They recommend 65 psi for 28s and 32s and I have been running my 32s at 65psi but weigh 82kg.
from my limited experience of running the gp5000 tubeless I would say 80psi is going to feel rock hard, particularly on a skinny like yourself; as a more manly [coughJust looked on their page & it says 80psi. I’ll adjust tomorrow & see if I can feel any benefit.![]()
] 110+kg I'm liking >70psi so farI’ll try 65 first.from my limited experience of running the gp5000 tubeless I would say 80psi is going to feel rock hard, particularly on a skinny like yourself; as a more manly [cough] 110+kg I'm liking >70psi so far
