Identifying my brakes
livpoksoc
livpoksoc
Basingstoke
Just thought the grooves being nearly gone was the indicator?
Otherwise it's just as I'm putting new rims on the frame soon. If they're fine as is, then I'll leave them and just loosen off the cable at tbe caliper end as they need to widen slightly to accommodate the new rims.
iluvmybike
There is a line around the pad - when the wear is down to that then they are shot. Once the 'grooves' wear away they are slightly worse at shedding water of rim but should work ok once you adjust the cable
Jenkins
Felixstowe
Those pads have got a fair bit of life on them.
This is how worn out pads look...
