How many of you use cadence for training ?
midlife
A higher cadence does not always mean you are doing more work.
Shaun
midlife
I think it's because cadence does not equal work (force x distance). It's work that makes the bike go..
Shaun
Citius
Shaun
Cadence doesn't really have any influence on work done, which is kind of the point, really. Although, for a given power output, a lower cadence will have less metabolic demand than a higher one.
Citius
You said if going faster was simply a matter of increasing cadence we would all do it
I disagree with this because increasing cadence in a given gear will make you go faster.
I didn't mean going faster 'momentarily' - I meant going sustainably faster. I assumed that was understood
Venod
Eh up
Yorkshire
Not sure you're getting this, tbh. Like I said before (maybe you missed it) - trivially, it does. But that higher cadence comes at a cost. You know the rest. Or maybe you don't - which is why I'm having to repeat myself.
Of course I,m getting it, you just have to increase your fitness, have you noticed Chris Froom's cadence?
Citius
I've noticed that it varies depending on what he is doing. Explain to me why Froome is relevant?
Milkfloat
An Peanut
Midlands
I think a good way to look at it is to think about cars. In a car for the greatest efficiently you need to be in the right RPM (cadence). To low RPM or too high and you are not burning fuel efficiently. To control the RPM you use the gears and accelerator. Obviously this is not exactly the same as cycling, but is a good analogy. I think the general consensus is that a lot of amateur riders ride in too slow a cadence, so increasing that cadence (RPM) will allow them to be more efficient. However, it seems that different people have a different sweetspot, just like an engine (think petrol v diesel or VTECH versus turbo).
Citius
because he is an example of a cyclist that predominately uses a high who used that high cadence to get results.
Someone needs to get back on youtube and watch a bit more of Froome, rather than just the highlights of Stage 10.
midlife
Cadence does have an effect on work as that's the distance part of the equation.
What a high cadence allows is for a lower level of force to be used. This has a number of advantages for certain individuals.
Shaun
Venod
Eh up
Yorkshire
Not sure what your suggesting I watch but wouldn't you agree that Chris is a high cadence rider.
