How many gears do we really need on a bike
Punkawallah
Can only use one gear at a time, ergo only one gear is needed.
Can only use one bike at a time, ergo only one bike is needed.
IGMC
Heresy! Burn them before their vile contagion spreads! :-)
Ajax Bay
East Devon
Given you can now get carbon frame bikes with 105 Di2 (12 speed), for around £2000, I think it is definitely moving into mainstream territory for keen cyclists. Not even close to a majority of bikes sold, but much closer to a majority of those bought now which will be regularly used on the road.
Incidentally, to answer the OP, you need as many gears as will provide reasonable gaps between the lowest you need and the highest you need.
What the lowest and highest you need are will depend on what terrain you ride, how fit you are, what sorts of loads you carry, and your purpose in cycling. Probably other factors as well.
Last two sentences: great answer. Can you do as well defining a "decent" bike for road use, and also "keen cyclist"? Clearly 12sp systems will slowly increase in number (a tiny minority of road bikes): does that mean they are "moving into the mainstream"? It's only because there are even more extreme systems being marketed that they're not completely on the edge.
I've looked for data but not found.
What's your recommendation for "a carbon frame bikes with 105 Di2 (12 speed), for around £2000"? Think maybe mechanical 12sp there'd be options but, as you suggest, what "keen cyclist" who "regularly rides on the road" buys a bike with 12sp and mechanical gearset nowadays?
https://road.cc/content/feature/six-best-bikes-12-speed-ultegra-8100-291189
https://road.cc/buyers-guide/best-road-bikes-under-ps3000
Alex321
South Wales
Probably not.
For me, a "keen cyclist" would be one who rides at least weekly, probably more, and not just because they have to or for utility reasons.
As for a "decent" road bike, it would be something said keen cyclist (assuming their preference was road for this bit) would be comfortable riding for the length of their regular rides, and which they didn't feel was holding them back due to weight or components.
https://www.sigmasports.com/item/CUBE/Attain-GTC-SLX-Disc-Road-Bike/ZW1W
I have an older version of that, with 11 speed 105 mechanical, which cost me £100 more than that one, in August 2021.
In the early days there were bikes with two gears where one of the gears was engaged by pedalling backwards. (Retro Direct)
For cycling that is done purely for exercise that might be a good thing to bring back as I'd imagine that backwards pedalling under load would add a new dimension to the workout.
https://retrodirectbike.com/
... and I'm sure it doesn't need pointing out to the learned assembly on this thread, but such a bike has been used to complete Paris-Brest-Paris in under 90hours (by a less-than-youthful amateur)
Dogtrousers
Kilometre nibbler
I didn't know that. I will get googling.
presta
Walking home from Tesco yesterday, a guy wearing a bright yellow rabbit costume passed me on a motorbike. I'm pretty sure that's not the right gear.
Dogtrousers
Kilometre nibbler
I'm surprised we haven't discussed the Classified Hub, a 2 speed planetary hub gear and so called "Front mech killer". Or did I miss it?
Planetary hub gears have - at a stroke - gone from things that were on your grandma's shopping bike, or are used by beardy, sandally long distance tourists from Germany, and are far too heavy and inefficient for proper cyclists (TM) to even think about - to being cool and trendy front mech killers (grrr) costing €2,400 and used by Filippo Ganna.
Now I'm not a knee-jerk luddite, I love new stuff (even if I don't use it) but even I have to ask "why".
Why has the world become allergic to front mechs? I can see how, on mountain or gravel bikes ridden over bumpiness, they might be a bit prone to dropping the chain. I don't know I've never done that. But I have ridden a lot on the road and I never (well, almost never) drop my chain. And anyway, the last time I can remember seeing a pro drop their chain it was Roglic in the Giro last year - on a 1x. Front mechs are about as maintenance free as can be - set them up right and forget them. Add a bit of oil to the pivots when you clean the bike. They are cheap. I put "Dura Ace Mechanical Front Mech" into google and it said they cost £70. That's virtually free for something with "Dura Ace" written on it. Tiagra front mech seems to cost £30.
And if you don't want a front mech then go for a 1x system. But why in the name of Sheldon would you go for a hub gear that does nothing that a double can't do (except cost €2400)
Edit: I've found out why. It's because "Shifting chainrings is quite slow, can’t be done under power, and requires a certain amount of consideration of the chainline." So that's me told. What a load of rubbish. https://www.cyclingweekly.com/reviews/classified-powershift-hub-first-ride-review
Ian H
Ancient randonneur
Twice, I believe (out of six on various unsuitable machines).
R
rydabent
All 3 of my rides have a triple. My shifting sched is simple. Granny ring up hills, center ring for the flats, and big ring for down hill with the wind. Shift across the rear as needed in those 3 situations.
