Vapin' Joe
Formerly known as Smokin Joe
- Bare headed cyclist, Smoker
They might have been on singlespeeds.
Nobody rode single speeds back then, unless they were just utility cyclists. It was either gears or a fixed wheel.
In the most recent copy of 'Cycle' there is a photo of three cyclists touring Wales in 1977. All of them were riding fixed, had one large saddlebag each and the ubiquitous yellow capes strapped to the top of said saddlebags. Oh and each had a 35mm. camera slung over their shoulder - !
How things have changed, or are we generally going soft - ?
Front shifters are dead! And hub gears are the New Big Thing! (at least in the Pro Peloton )
Nowhere near as much as a recumbent tricycle frame though.I guess you like that 10 pound 12 speed cluster in the back. They must weigh as much as some frames.
Yes indeedy, Alex, but the bent bloke is referring to a Classified cassette which, bargain, costs 118 pounds, reduced from £169!The Shimano 105 12 speed cassette weighs 361 grams. Considerably less than a pound, and that will be the heaviest of their 12 speed road cassettes, being the cheapest.
I think you're complaining about something that doesn't exist.
Triples aren't particularly fashionable these days. 12 speed groupsets are the cool and trendy (and expensive) ones and they tend not to come with triples as an option. 2x or 1x only. I think you'll only find triples for 10 and fewer speeds - Deore and Tiagra and the like. If you go and search for an off the peg bike with a 12S cassette and a triple I doubt you'll find one. I'm not certain, and I'm not interested enough to go looking so I could be surprised.
There's a challenge for you: Find an actual off-the-peg bike on sale with 36 gears. It will be interesting to see what, if anything, you come up with.
There was, and is, always the option to get off and push. Just saying :-)
What cassette or block have you got on the recumbent?I have a long wheelbase recumbent and a trike. Both have 20" rear wheels. The gearing on both seems to be the same as what normally comes on 26" bikes. But even then, I could use at least one, preferably two, lower and higher gears.
The recumbent is a 7-speed. The trike is a 16-speed. If the gear spacing on the recumbent was spread out more, it would probably be okay. The gear spacing on the trike is so close I can barely tell the difference when I shift. So in my opinion (*) the problem isn't "how many gears" but "how wide is the range."
My riding area has a lot of steep hills and humpback bridges, intersperse with miles of absolutely flat paved bike paths.
(*) newbie cyclist, still getting used to how things are done, and in so-so physical condition
