SavageHoutkop
- South Manchester-ish
What would be better here is an ASL to get the bikes all the way to the front.
How would that be better?
Either you're in front of him anyway (and I'm also wondering about Origamist's comments - could you clarify - is it that if you are too close to the front of the cab you are invisible as the line of sight is not straight down?) or you need to ride up the inside to get to the front; in which case you run the risk of the lights changing as you do so and you're in the same position.
