The highest flow temperature you're likely to get with a heat pump is 55°C, and the more efficient installations use 35°C. Hot water will normally be about 10°C cooler than the flow temperature, as heat transfer becomes slower and slower as the differential decreases, although if you are prepared to wait infinitely long it could just about get to flow temperature. So it's going to be rather tepid if you're used to a conventional system, unless you flog the heat pump pretty hard.
What scares me most about heat pumps is the supposed necessity of running them 24/7 to keep the house warm, because their output is too low to raise a house from cold in any reasonable time. I want a cold house at night or if I'm out. People who see big savings were probably heating the house 24/7 on gas too, rather than just for 4-5 hours in the evening.
