Presumably the reason heat pumps need such an enormous hot water tank is that if a small one ran out the HP wouldn't produce enough power to reheat it in a sensible time?Combi-like behaviour is not required to suit many times. After all, it didn't used to be an option before artificially cheap North Sea Gas.
https://www.hse.gov.uk/healthservices/legionella.htm
60°C is the safe minimum. If you heat to less, you need a weekly legionella cycle when it gets hot enough to kill any bacteria.
I was talking to the bloke over the road just before
The subject of heat pumps came up and apparently he knows several people who have had them installed
Not one of them has a good word to say about them
The 1950s called and want that heat pump back. Many go hotter now, but few people want their hot water to be a scald danger at the tap and anything above 50 kills Legionella when the tank insulation means it stays that hot for hours. The heating loop is run cooler but that's a sealed system with additives, not something you should be inhaling anyway.
A common misunderstanding! The ASHP controller is left on 24x7, rather than the bad old timeswitches commonly used with overpowered fossil systems, but it will only run the pump continuously when it's below the design temperature (-3°c is common) for a prolonged time and that's rare. Even then, it is possible to boost heat if needed, it just costs more. It's not as quick to lift the temperature as an oversize combi but that's massively inefficient all the time anyway.
Our oil heating used to be on maybe 2 hours mornings and 3 or 4 evenings. The ASHP controller doing what it wants all day is cheaper and we almost never have to think about pressing buttons.
My second cousin twice removed was talking to a bloke in the pub who said he'd heard that heat pumps don't work. Evidently all the people in the Scandinavian countries who've had them for decades were only imagining that they worked and had actually frozen to death without realising it.
I'm sure the bacterium knows and respects the difference!That's for a commercial property.
Before considering a heat pump the insulation must be up to scratch and hor the majority of British housing there’s much to do. Triple glazing, that’s going to be very expensive £15,000. Loft insulation £2,000. Cavity wall insulation, if you have a cavity, £2500, and if no cavity £25,000 for external cladding insulation. Now you are ready for the heat pump but if like most people with a Combination Boiler your going to need proper heat retaining insulated storage which is going to be very expensive plus the heat pump itself. This is possibly why the heat pumps aren’t disappearing off the shelves.
On a happier note Lincolnshire is sitting on a huge Natural Gas field it would make sense to utilise this bringing wealth, prosperity and employment to a needy area of Britain. I rest my case.
It is not only the insulation
It is also checking the insulation
Our house was built with cavity wall insulation in the 1980s (or so)
but the standard was not that good
They use small polystyrene balls - and apparently they were supposed to include a light glue so when the balls settled they stuck together
but a lot of builder saved money and effort by not using the glue
when a house round here has a hole of any size drilling in the wall it looks like a Christmas card - snow all over the place
and many years ago, when people first replaced the windows for double glazing - then every time the whole area around the house was covered in the stuff
so a lot of the insulation has just come out
so before it can be relied on you really need some kind of assessment of what is remaining and how good it is
and I can find no reliable company locally that offers to do it
apparently some counsels have a scheme where you can hire an IR camera and you can use it to see the heat radiating from you house
but I have also read that it really needs some training to do it properly
which is another cost - plus fixing the results
it is all a bag of worms - and the adverts and stuff on the telly make it seem all so simple
which makes me suspicious
I wouldn;t spend a significant amount of money on it without a proper written guarantee backed up by something solid
They clearly work
If the house is suitable and the system is appropriate for the house
A lot in this country are not well enough insulated and a lot of system have been installed badly or were not the right ones for that house
or that is what I have read
